Results 1 to 8 of 8
Thread: My e34 runs fine then dies out
    Apr 2007
    Buffalo, NY
    Default My e34 runs fine then dies out
    My e34 runs fine for a couple minutes, then starts running like **** and won't move. Thought it may be a clogged cat so I pulled the exhaust off, it's running open header right now. Put a scanner on it; no problems, even though once it starts running like **** it throws a cel. It said it's getting 1.12v at the o2 sensor, but the o2 sensor isn't on there.
    I just dont understand because it runs perfect for the first few minutes. good steady idle, etc. I don't understand what it could be? As soon as it starts warming up it dies out. When I put the scanner on it when it started running like **** after I started it and ran it for a couple minutes it was at 54 degrees celsius (~129F)
    any ideas? coolant temp sensor? sending unit?
    Feb 2007
    GreenHills East-Philippines
    check the temp.sensor, and might help you better if we know what kind of e34 that you drive
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Apr 2007
    Buffalo, NY
    92 525i m50
    Apr 2007
    Buffalo, NY
    anyone?
    Aug 2007
    KY
    Andre,
    Have you tried swapping out the coolant temp sensor yet?
    That would be one guess.
    Sep 2007
    Michigan
    What happens if you run it with the gas cap loose? In the driveway, not on the street. I'm wondering about a fuel pressure issue or a clogged fuel filter.
    I'm assuming it does the same thing with the exhaust removed.
    As BMWrp8 said, check the temp sensor. Actually, check both the engine temp sens and the coolant temp sens. The two are located below the intake man. and can be seen in the left of the photo below cylinders 1 and 2.
    Bentley has the testing procedures. However, if I recall, the coolant temp sens involves boiling water etc., so isn't super friendly to diagnose. You may want to try removing the harness for each one while the engine warms to see if one is suspect. The DME will allow the engine to operate with either of the sensors disconnected.
    Otherwise, a cat code could be one of many things, including throttle position sens, ICV, CPS........... Let us know what you find.
    Dave M
    Apr 2007
    Buffalo, NY
    it was a bad dme
  1. 89 525 dies when put in gear
    By barry 90 525i in forum 5 Series BMW
    Last Post: 10-27-2007, 09:21 AM
  2. car dies, need help
    Last Post: 07-21-2007, 07:07 PM
  3. Need help with Trans Mod indicator but trans runs fine.
    By bimerguycw in forum 3 Series BMW
    Last Post: 02-05-2006, 09:34 PM
  4. Replies: 7
    Last Post: 12-03-2005, 02:55 AM
  5. Runs fine when cold! But dies when getting warm! 735i e32
    Last Post: 03-28-2004, 10:23 AM
