for bmws? i don't think they exist for most models, generally not needed either as these things were built with high speed running in mind, m20s are pretty much bullet proof on oiling except for hard left turns in racing, m30s occasionally have a relief valve problem bleeding off pressure and the check valve in the canister on b35s can let the oil drain out of the filter causing a 5-10 second wait for the light to go out, plus they have the same left turn racing problem (pressurized resevior like a accusump or a good baffle will solve this on either motor) the oil pump falls off of the v8s, the bolts back out and the pump falls off, m50s are pretty solid, sometimes it's possible for the gasket where the pick up meets the pump to crack and suck air (atleast that's one of the suggested causes for lifter tick)
