Originally Posted by
8 POTS
Thanks for input
As suggested I went over fuel supply again, hooked up a pressure gauge on the fuel line, everything seemed fine with regard pump delivery pressure but working of regulator and hose between regulator and intake manifold was a bit suspect. So picked up seccondhand one and fitted it, also replaced hose.
And car is now much better, pulls nicely specially after 3100 + rpm (vanos). So presume mixture was too lean causing knocking and triggering knock sensor fault code.
Performance still not totally what I think it is capable of, but this probably due to age and neglect by previous owners, old coil packs, minor vacuum leaks etc. maybe will work through all that one day.
But happy for now.
