tilt the motor down a little and pull the cable out of the motor.. then attach a drill chuck to the inside cable end and spin it with the drill until the seat is even and not twisted... once you have it even you pull the center cable out of the jacket, then pull the metal end off the jacket and cut 1/4 to 1/2 off of the jacket then heat up the metal end with a lighter and push it back onto the jacket while its hot until it seats... then reinstall the cable into the jacket all the way and check one last time to make sure the seat is even without twist, then reinstall cable and jacket into the motor and replace the 2 screws that hold it in..
Originally Posted by gamjohn2
