Since you bought the hardcopy
The idea is simple, but you have to turn/toggle the wheel the right way. I don't recal the correct direction. Between removing the glass pane and removing the mirror housing (the first step is in the pic above, the remainder is sef explanatory), you should be good to go.
Hope this helps.
Dave M
