Results 1 to 10 of 13
Thread: Flat battery, can't open door locks
    ngruzevs@optusnet.com.au Guest
    Default Flat battery, can't open door locks
    Yesterday I left my parkers lights on, (1989 535i E34) all day at the train station. When I returned to my car, the battery was obviously flat. To my surprise I couldn't open either the driver or passenger front doors with the key, the central locking obviously relies on battery power. I couldn't get into the car and therefore couldn't open the bonnet. I therefore had to call the Roadside assistance, the guy laughed and said he's had this situation before. He jacked the front up and found 12v underneath the bonnet to connect some jumper leads and I was then able to open the car door with my key.
    Is this normal when the battery goes flat?
    My mate has a 1987 525e, he said turn the key to the left and the door would open, but I didn't.
    That is a common issue when the battery dies. Here's some info about it: http://bmwe34.net/e34main/trouble/Locked.htm
    This same thing happened to me a year ago. Well, bus station.
    Don't try to wedge the door and use the coat hanger trick to pull up on the locks, they ratchet down so no one can steal your car. Nice huh?
    Anyway what we ended up doing was getting a really long hook, wedging the door and pulling the hood release.
    Wellington,New Zealand
    i ran my battery run flat last nigh(left the parking lights on)The mergency pprocedure worked for me,ie lifting the handle and turning the key at the same time.Had to have a few tries,on the third attempt the lock lifted a little,fourth attempt it lifted nearly all the way and the last attempt finished the job.I had jumper leads with me so all i needed was a friens help for a few minutes to jump start
    Gone but not forgotten
    Hobart, Tasmania, Australia
    Use the boot (trunk) light method on the E34 website listed above... thats how I sorted out my old gal!! Connect a battery charger, and leave it for a day...
    Uncle Robert!1!!
    Gone but NEVER forgotten. :'(
    And then...
    Charleston, SC
    same question, my two keys say "S" and "E"
    whats the difference?
    '90 535i
    UUC SSK, Bilstein shocks, Eibach spings, EAT chip, CAI, Super Sprint exhaust, Hella euro headlights, HID kit, M5 spoiler
    Dec 2006
    Long Island
    if the car is double locked or deadlocked you cannot pull the door lock pins up.
    You also can't use the hold the handle up, turn the key, and lift the handle again trick if it is double locked. Regular locking then both would work.
    I've always been able to get into the trunk, and I've actually heard (probably here) someone's sister climbing in through the ski passageway to unlock the doors. I'd just hate to get stuck 1/2 way through and try and figure this one out. My trunk struts are shot, so most likely get closed in and die.
    Completely off topic...
    Where are you, Noob??
    Judging by the email, you are an Aussie??
    So am I... Reppin' the Apple Isle!!
    And then...
    Thanks for all the suggestions.
    What key is the master key?
    I have only one original key left, it has an "S" printed on the metal part. My other two keys are copies.
    Nick
    Correct, I'm an Aussie from Melbourne.
    I have a stock E34
    http://members.optusnet.com.au/~ngru...%20(Small).JPG
    It gets parked at the station every day, therefore I don't put any money into it.
  1. battery flat, deadlock engaged!! how to open door?
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 07-23-2009, 10:27 PM
  2. Replies: 8
    Last Post: 06-18-2006, 05:26 PM
  3. HELP please - flat battery
    By simon-york in forum 5 Series BMW
    Last Post: 07-24-2005, 01:32 PM
  4. Hood Open, Door Open, Trunklid Open
    By MDT in forum 5 Series BMW
    Last Post: 07-20-2005, 02:25 PM
  5. door locks don't work....stuck open
    By motuman in forum 5 Series BMW
    Last Post: 03-18-2005, 10:18 AM
