The crack is down the bottom. Drizzle some silicone into the bottle at the right angle to coat the bottom near the bottle's lower body mount. I tried on the outside and it didn't work... I used Hylomar, but silicone would be fine. (make sure you clena the bottle with some shaken hot detergent laced water, then let it dry for a few days in a dry spot before drizzling in the silicone. It is the only way to a lasting repair if yours is a stress-related/age fracture like mine. NickOriginally Posted by Kibokojoe
