yeah. you need to fix it.
you'll need to loosen the hard pipe connection under the intake manifold. 10mm bolt. undo it then undo the clamps on that 1 inch line. replace it. be sure to use fuel injection clamps and pressure rated (fuel injection) hose. don't use regular low pressure fuel line.
if you leave the car parked for 3 or 4 hours before you do all this, you'll have minimal residual pressure in the fuel lines. it will still bleed out a fair amount of fuel (< 1 cup) so have some rags handy.
jeff
Bellevue WA
86 Porsche 951 - Track Toy
