Results 1 to 10 of 12
Thread: Screen freezes inside
    Oldham, England
    Default Screen freezes inside
    OK -4 deg C is nothing to some of you on here. But I'm getting fed with having to wait 5 minutes till the car warms up and clears the ice off the INSIDE of the screen. Before winter the windows would steam up if the car was left in the sun so I'm thinking the problem is condensation. Carpets are dry but water must be getting in somewhere. I just cant find where. My guess is the boot as the tool kit was a bit rusty when I got the car. Any suggestions on places to look and if not, how do you guys in the really cold places get around this problem?
    Feb 2007
    New Forest, ,UK,
    Got same problem but slightly warmer.Mine has been getting into car from top of screen when prat put new screen in 6 years ago. Try jet-wash on top of screen to confim. The boot water leak will be seal. looks fine but is not waterproof, costs peanuts.
    Dec 2006
    we get around it by sitting and waiting for the car to defrost - sadly, that's the best option.
    Jul 2007
    montreal
    Default maybe check sunroof drains anyway
    Quote Originally Posted by repenttokyo
    haha what- you sit in the car and watch your girlfriend dig you out of the snowbank?
    yeah ice is the worst thing for cars, doesn't matter if it's -1 or -40. actually i think it's worse for your car if the temperature hovers closer to 0'C because wherever that water is it's expanding or contracting every time the temp passes zero... here for the most part it just stays frozen. after driving various cars and trucks around planet hoth for twenty years or so and seeing what it does to them (combined with the salt-ugh) i long ago made leak avoidance a priority as far as car maintenance goes (should have made it the water pump with this car, but that's not relevant here).
    i had lots of leaks but i think i got them all (i can't tell, my car's in the phXXing shop). when i had a sunroof drain blocked, most of the water ended up in the ds carpet, but it travelled from the blocked front drain on the ps across the top of the windshield (on the inside). probably not your problem but it's so easy to check the drains maybe you want to. i also had a plug/grommet/thing loose between the fusebox and firewall and some water was getting in there- it's between the f/b and the ds wiper motor on my car- i forget exactly where. also if you have even a small hole in any of your wheel-wells pressure could force a lot of water through into the space behind your dash or maybe into your trunk.
    when i was figuring this stuff out i would let my car sit in different angles in the rain and check it before driving it - or try to keep it dry and then drive through lots of puddles just to try and narrow down the source a bit. my neighbours still can't figure out why i used to water my car every week! -hope some of this helps...
    ...help me i'm freeeezing...
    Oldham, England
    Default Screen freezing
    Thanks for the responses. I dont THINK I have a leak cos the carpets are all dry. But water must be getting in somewhere. If the local wash isnt frozen I'm off there tomorrow (she thinks I'm getting her presents) and have a very close look to see if I can find a leak. If you guys who live in really cold places dont have a solution maybe I should try so hygroscopic crystals? Unless I get caught AWOL will post outcome
    you have a heater core leak bro! if not to bad relax if the carpet is dry. Simply put the thing on hot and turn the AC on and the sheild should clear fast and stay clear. Adjust the proper settings and you can live with a leaky heatercore forever.
    Oldham, England
    Getting shopping yesterday wasnt the best idea. Took forever. So I didnt get to the wash Had time to take a quick look at the heater area and couldnt see any runs. Maybe I'm misunderstanding, but if I put it on hot the AC wont switch on. If I put it on cold then it will. Makes sense or the AC would be fighting the heater wouldnt it?
    Feb 2007
    New Forest, ,UK,
    Its a good idea to use the A/C on hot as it de-humidifies, mine does.Not sure about heater core leak as mine uses no water at all despite having same problem as you. My passenger side carpets are wet from screen leak,and rear drivers` side boot pocket fills up due to seal.Also found tray behind seats in floor full from somewhere! Get rid of all water and car is clear for a while,reckon you have a leak somewhere allowing water to puddle in hidden corner,Screen,sunroof drains,boot seal?
    yes the ac fights the heat, mine runs on hot and clears the sheild in seconds VS just the heat which never seems to clear it. Maybe something about the year of your car... try kicking it on cold and turning the temp to hot when the AC is on?
    Quote Originally Posted by whiskychaser
    Great Britain
    It could be a leak between the windscreen and the chassis. You could check for that by putting soapy water around the rubber on the outside of the windscreen and then using a compressed air line to blow air all around the inside of the windscreen. If you get any bubbles then you've found a leak.
  1. What does your screen name mean?
    By Ross in forum 5 Series BMW
    Last Post: 07-15-2007, 12:45 AM
  2. 525iT FREEZES...condensation in the tank? HELP!
    By aviatorb747 in forum 5 Series BMW
    Last Post: 03-18-2007, 06:21 PM
  3. OT, on the big screen tv thread, thanks for all
    Last Post: 07-18-2006, 08:34 PM
  4. OT, Looking for info on the best big screen
    Last Post: 07-11-2006, 08:17 AM
