Pull the fan motor and re-oil the bearings and the felt that holds oil >>
Originally Posted by
Black 535i
Recently when the weather is cold, my blower fan is making screaching noises until it warms up or if I turn the fan speed up. I am assuming that this is the problem as it sounds like it is coming from this area in the dash. Is there a place to lubricate anything here or is this a sign of some sort of unit or bearing failure? Real OEM lists the part at $273.00 new and I have better things to do with that money but I may be able to get it much cheaper from a donor car. Is this a good fix or no? Anyone else have any idea what could cause this squealing sound? How does one get to this part to repair anyway?
http://picasaweb.google.com/RecordCampy/BMW
I have done this on both my e28's (similar location of motor) and they have been quiet for 3 years now. Don't use WD40. Use something like 20 weight. I used 5w-30. As mentioned in the other post, you have to remove the expansion tank and then the fire wall cover. Tedious, but doable in an afternoon.
Best of Luck.
Jeff in MN
87 535is 245k Recent top end re-work
88 528e 290k
90 535i 115k
98 740i 115k New Magnaflow Cats, No More Codes
