All retail battery providers can tell you the proper battery code. Just go there and get one.
Interstate battery code? I need a new battery, bad!
Which should I get?
EuroLux:. Private Detail
Greg Mannino
Here is what Interstate comes up with for your/our cars: http://www.interstatebatteries.com/e...CRank%7C1&js=1Originally Posted by CharlesAFerg
I just put this one in mine (I did however move the battery under the right rear seat):
http://www.interstatebatteries.com/e...archGroup&js=1
I had the previous Interstate battery MTP-93 for 7+ years before it would no longer hold a charge. $118.00 installed including new vent tube.
M20 525/7 Bore: 84.50mm Stroke 81mm CR 8.5:1, blue printed/dyno & custom chip. Boost @ 6.5psi ~246hp @ 5300rpm / torque @ 269ftlbs. @ 4250rpm
take a ruler and measure the length. tell us what it is, and we can tell you if you can use a group 49. which seems to be the best deal going as far as "power" goes, and is what most e34s use.
