Results 1 to 3 of 3
Thread: '86 533i surge question
    Default '86 533i surge question
    Brother has '86 533i which surges after warmup.
    It starts and warms up normally, but then after warmup it idles at ~1,000 rpm, then momentarily surges to ~1,200 rpm, then back to ~1,000 rpm, continuous pattern. Slight clicking sound from the electric valve between the intake manifold and vapor canister.
    Got suggestions as to diagnosis and cure?
    Dash01
    '90 535ia 272K miles
    Mar 2004
    Is this a UK car? A 533i wasn't offered in US in '86, so this may not help.
    The clicking from the solenoid valve is likely a consequence of the hunting idle. This valve opens/closes at an RPM just above idle.
    Is the AC compressor cycling?
    Solve the fast idle problem and hunting might go away. Should idle at ~850 rpm. Check throttle position switch adjustment. Engine won't idle correctly if TPS doesn't see an idle postion. Check vacuum hoses to fuel pressure regulator, idle control valve, evap fuel cannister, vacuum hose to interior temp sensor. Check idle control valve. Does it have a bypass screw adjustment? Count the turns it take to close it completely and record. Close completely and open 1/2 turn only. Remove idle control valve and clean w/ carb cleaner.
    My US spec '83 533i had a similar problem. My idle speed varied intermittently a hundred rpm or so, but didn't hunt. One stop light idle would be normal, at the next it would be 100 rpm high. There is a temp switch in the thermostat housing that turns off the fast idle as soon as coolant gets to ~40C. As I recall it's the sensor with the (2) separate spade connectors. The (2) terminals on the switch had rivetted connections. The rivets had worked loose creating an intermittent connection. I was able to repair the connections by soldering.
    Paul
    Quote Originally Posted by Dash01
    Thanks, Paul, my bro appreciates the insight and advice. Turns out, his 533i is an '84.
    Dash01
  1. Convert 528e to 533i?
    By AngryPopTart in forum 5 Series BMW
    Last Post: 08-10-2008, 09:32 AM
  2. tell me about tuning the 533i
    Last Post: 06-30-2008, 08:14 AM
  3. My 533i
    By Shotgun Lobotomy in forum 5 Series BMW
    Last Post: 10-02-2006, 11:33 AM
  4. 1983 533i questions
    By mystical_wings in forum 5 Series BMW
    Last Post: 02-21-2006, 12:18 AM
  5. 92 525i idle surge question
    Last Post: 05-30-2004, 12:02 AM
