Results 1 to 3 of 3
Thread: Hanging shift in 3rd on ZF 4HP22
    Mar 2007
    San Francisco
    Default Hanging shift in 3rd on ZF 4HP22
    I want to say this is a smart transmission, but I am hoping it's not a tranny failure symptom. Every so often when I climb a slight grade at a moderate speed, the tranny seems to hang on to 3rd gear for a long while. Not sure why, not readily able to duplicate the problem. It still stays in 3rd even when i let off the gas and coast for a flat straightaway.
    I'm usually going about 40 mph, 35% open throttle. I know Honda's transmissions have a grade-logic scheme, but does this wonderful machine have something similar too?
    _______________________________
    1990 535iA Glacier Blue Metallic 114k
    i'm pretty sure mine will go into 4th unless in sports mode
    Jersey, C.I. - UK
    Mine ('88 535ia, same) only really shifts to 4th above 40mph on the flat, so up a gradient it will hold on to3rd if your speed is around the shift point
    Has always done it, so I assume perfectly normal & nowt to worry about
  1. Throttle Lever Hanging Up On Cover
    By filmy540i/6 in forum 5 Series BMW
    Last Post: 11-14-2007, 04:54 AM
  2. '95 E36 325is wire hanging down
    By Dash01 in forum 3 Series BMW
    Last Post: 11-03-2007, 03:54 PM
  3. Spent the day hanging over the indy’s shoulder
    By Gayle in forum 5 Series BMW
    Last Post: 12-17-2005, 11:33 PM
  4. whalen shift knob short shift combo - E39 2000
    By peffer in forum 5 Series BMW
    Last Post: 09-13-2004, 11:41 AM
