Results 1 to 4 of 4
Thread: E34 sport seats - disassembly help needed.
    Default E34 sport seats - disassembly help needed.
    Anyone know how to remove the back from the base on the E34 sport seat?
    Specifically, I need to swap the seat wiring harnesses between two sport seats and I can't figure out how to remove the harness where it traverses through hinge. It appears I need to separate the base from the back.
    The BMW factory manual is not clear on the procedure.
    Any help appreciated!
    Thx,
    Jeff
    Bellevue WA
    86 Porsche 951 - Track Toy
    Hey Jeff - what's new?
    Here's a pic from RealOEM:
    http://www.realoem.com/bmw/showparts...41&hg=52&fg=25
    might help...
    Robin
    72 Chevy K10
    01 E39 M5
    Hi Robin...
    Same old same old.
    I'm in deeper than that - trying to remove the back frame from bottom. I put a post on UUC and it looks like I have an answer. There's a couple of spring loaded pins that need to be pushed out of the way and the back lifts off.
    Bellevue WA
    Here's the answer courtesy of Brett at KMS.
    Remove the backrest cover.
    About 6" above each pivot point is a lever. Depress the lever and lift
    up. It usually takes a pair of channel lock pliers to get the force
    required to release the levers.
    The entire back rest assembly will come off the two posts that are a
    part of the reclining mechanism.
    Brett Anderson
    KMS
    Bellevue WA
  1. Know of any Sport seats 4 sale ??
    By Booster in forum 5 Series BMW
    Last Post: 01-25-2008, 08:33 PM
  2. Do Regular E46 Sport Seats Fit?
    By Panzer Captain in forum 5 Series BMW
    Last Post: 09-27-2007, 09:31 PM
  3. sport seats into a 535
    By angrypancake in forum 5 Series BMW
    Last Post: 09-21-2006, 12:31 PM
  4. E34 Sport Seats
    By gtopaul in forum 5 Series BMW
    Last Post: 08-24-2005, 04:44 AM
  5. Sport seats?
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 07-03-2005, 08:37 PM
