if you don't have a ce light are you sure your car came with a 02 sensor? to do a useful test on a sensor you really need a graphing meter and a propane torch, i find the sensors hardly ever totally die they just get slow, the injection system when not at full throttle constantly swings from lean to rich, when the sensor's reaction time gets slow this throws off the computer. how i run the test, get the sensor in a vice and hit it with the torch while watching the readings, with in 25 seconds it should be over .750mv dc, it should remain over .850 mv dc with the torch pointing at one of the slots/holes of the sensor, now for the part that a graphing meter is helpful on, after about a minute and a half of full heat when you take the torch off of the sensor voltage should drop to near 0 in about a tenth of a second. the two white wires are the heater, check these for contineuity, if open the heater and the sensor is dead, the black wire is the signal, this is the one you hook the red meter wire to, now for the ground, if it's a a 3 wire sensor hook the black meter wire to the body of the sensor, if it's a 4 wire unit hook the black meter wire to the gray sensor wire
