Do a leak check on your intake manifold by spraying MAF cleaner on the gasket area... Do not use carburator cleaner. You want to hear for engine characteristic change.
I probably would bet on four things at the most...
1. Spark plug... change them to single electrode type. As Jon K recommends.
2. Spark plug boot... newer version of boot is redesigned and different.
3. ICV... but do this along with your intake manifold gasket and the waterpump bypass tube in same area... which means waterpump too.
4. MAF... This is probably the most likely reason. if not number 3.
