Unbolt the slave cylinder & rotate it to position the bleeder to be topmost part. Then gravity bleed the thing. Don't pump pedal too much with slave unbolted, or the rod will come out.
clutch on his '85 635csi & is having trouble with air in the system...any suggestions I can forward to him? Thanks. Bill H.
erased due to slander
in the morning - I was wondering if there might be air in there.Originally Posted by Martin in Bellevue
How's your car running?
- Robin
Robin
72 Chevy K10
01 E39 M5
I've heard blocking the pedal down overnight helps the air bubbles to rise up to the reservoir. Sounds like a giveup technique.
Maybe someone should build a bracket to bolt the slave to, in order to capture the rod for bleeding. Pushing the rod to bottom by hand might help move the air up.
My car is good.
