Results 1 to 8 of 8
Thread: Transmission input shaft movement?
    PA
    Default Transmission input shaft movement?
    Hey guys,
    Just remembered that I wanted to ask this question. When handling my trans last weekend the input shaft is straight and does not have any in and out movement, but it has some up and down movement. Its VERY minor... like, I'd have a hard time even measuring it... maybe .5mm ... maybe.
    But, what is the allowable movement on the shaft and how do you fix it?
    PA
    anyone? i heard there is a bearing behind the guide tube or whatever its called that fails and makes the input shaft rattle in neutral
    El Paso TX
    nothing in bentley Jon?
    you check the nut behind the wheel yet?
    May 2006
    Antwerp, Belgium
    Wouldn't the clutch throwout bearing compensate for this?
    2008 audi A3 1.9tdi
    (former 1991 520i LPG)
    PA
    Morgenster no the TO bearing isn't designed for this. There is a bearing supporting the input shaft. Hrm.
    PA
    I decided to leave it - if I have an issue with it I'll switch to a ZF 320
    Some axial play is normal, but I couldn't tell you the spec of the top of my head, it should be in the repair manual (actually, maybe not if it's the ZF).
    Yes, the bearing can be replaced. On the Getrags, you have to press off the front half of the case, you can then replace the layshaft bearing and input bearing. The input bearing is shimmed, so it needs to be set correctly (and there is definitively a spec on that), or there's the risk of MORE axial play (and more noise). Chances are that the existing shims will be enough to do the trick.
  1. Tire rod movement?
    By Jehu in forum 5 Series BMW
    Last Post: 04-14-2007, 04:25 PM
  2. No movement in Reverse when the car is cold.
    By amsmk in forum 5 Series BMW
    Last Post: 03-05-2004, 09:43 AM
