Results 1 to 5 of 5
Thread: 520i auto n reg
    Derbyshire, UK
    Default 520i auto n reg
    I assume you've checked for all the usual suspects, i.e., clogged fuel filter, intake air leaks, bad spark plugs and/or coils, low compression, clogged injectors, wonky transmission, VANOS problems, dirty air filter, etc.?
    Also, a 520i is going to be naturally slower than an equivalent 525i -- the extra displacement does make a difference.
    1997 535i V8
    Hi just got 520i auto 24v 1995 for my bro its very slow all through the range. my dads 525i auto 24v k reg 1993 goes like the wind. i do know my way round cars maybe its the air mass meter as we had this with a 7 series. might try my dads air mass if its the same number on it. like to here what you guys think.
    best regards paul
    Hi dave thanks for the reply no iv not looked at any thing yet. as we only got the on sunday i will look at all those things. but when you say vanos probiems what do you mean. it does have a bit of a rattle when first starting at the front of the engine . which i think is a bit of wear on the vanos. i know what you mean about the 525 being faster but the 520 is just so slow i think some thing must be wrong some where
    regards paul
    Look for obv signs of some pov hondaengeneeerz messin' wid da vanos and consider getting a top cover gasket kit before u start pulling her down. If you need to fix the vanos, look into what you have to do, I don't think it's easy but at least (since u you are in the UK) you can button it up every time it rains or gets too damned cold to work on.
    Might be worth buying a 2.5 M50, electrics, computer+gbox from a wrecked 525 dep on what you can find and do... g.luck
    Oldham, England
    Quote Originally Posted by genphreak
    Wow! You come from Bolton?
  1. e32 735i auto in 89 535i auto?
    By joshuagore in forum 5 Series BMW
    Last Post: 11-11-2009, 07:14 PM
  2. My 520i
    By robin in forum 5 Series BMW
    Last Post: 05-30-2006, 02:48 AM
  3. Auto shift e34 520i 95
    By andrew piper in forum 5 Series BMW
    Last Post: 01-22-2005, 01:30 AM
  4. NEED HELP WITH 520i E34 M20
    Last Post: 06-04-2004, 05:05 AM
  5. E34 520i Auto Idling explanation needed
    By bal3056 in forum 5 Series BMW
    Last Post: 05-07-2004, 01:33 AM
