Thread: Relays next to DME
    Jul 2007
    Canada
    Default Relays next to DME
    From my understanding, this is what you should find under the DME covering panel (with an actual relay for the fuel pump instead of a fused switch):
    However, on my 10/88 Build Date 535iA, there are only 2 relays. One is the DME relay, and the other is a mystery orange/yellow-coloured relay with part number 61 31 1 376 301. When I put this part number into RealOEM, nothing comes up. Is it the fuel pump relay? O2 sensor relay? Would the new orange coloured relay P/N 61 36 1 378 238 work in its place, as shown in this diagram?
    http://www.realoem.com/bmw/showparts...54&hg=12&fg=35
    Could it be that 535i's don't have O2 sensor relays?
    -Emil
    1988 635CSi - 1989 535i
    My 4/89 built 535 is the same. I forget which relay has 4 pins and which is 5, the 5 pin can be substituted for the 4 pin, but not the other way. The 5th pin is a normally closed contact the 4 pin doesn't have.
    These are standard relays and can be had for a couple bucks a piece if you browse the local parts stores electrical suppliers catalog rather than ordering for a specific application.
    PA
    Where are you located? I remember some euro cars do not have oxygen sensors.
    I got to thinking about this so investigated.
    The fuel pump and O2 sensor share the same relay, the four pin one whichever color it is, orange I think.
    Jul 2007
    Canada
    Jon: I live in Canada, and my car definitely has an O2 sensor. Ross: Would one of the later style relays (separate for O2 sensor and fuel pump) be interchangeable?
    According to the Bentley one of our 5 pin relays doesn't have a N.C. contact but has the 87 &87a terminals joined. I suspect Bentley is wrong and it wouldn't be the first time.
    I think you are refrring to the 4 pin, so yes a later 4 pin should work.
  1. 5 pin switching relays
    By Ross in forum 5 Series BMW
    Last Post: 09-08-2006, 04:08 PM
  2. Relays
    By cpbrinks in forum 5 Series BMW
    Last Post: 07-30-2006, 05:29 AM
  3. DME & Fuel relays
    By old bob in forum 5 Series BMW
    Last Post: 07-25-2006, 10:34 PM
  4. Relays
    By schematic in forum 5 Series BMW
    Last Post: 04-18-2006, 03:15 AM
  5. relays FAQ
    Last Post: 12-14-2005, 11:57 PM
