Results 1 to 5 of 5
Thread: Quick Question from ECT Replacement
    NW GA
    Default Quick Question from ECT Replacement
    Not a pic of my car, but just one I googled for an example. Could someone tell me what this little item that I have circled in red is, what purpose it serves, and more importantly, where the tube coming out the top of it, the one that on my car was so brittle it crumbled when I accidently bumped it when repplacing the ECT, goes.
    Thanks.
    1990 535i 5-sp., except for 16" M-Contours, cd deck, and clear corners, completely stock. 226k and running strong
    Benneton (United Colors of)
    that is your fuel pressure regulator, and the hose should go to somewhere on the intake manifold. i suggest you use realoem to follow it back down, as i have an m50, and only know where the hose on that goes.
    Australia
    It goes to the underside of the intake manifold directly below the throttle body.
    Most easily found if you get under the car and use a light.
    NW GA
    I can't seem to find it on Real OEM. Any clues?
    Quote Originally Posted by Mitch90535im
    Reach under the throttle body, on an M30 engine there are two vertical pipes sticking out (hanging down). One takes the pipe that feeds manifold pressure to your Fuel Pressure Regulator, the other goes to the vent pipe on the valve cover.
    Replace both- and check all your other hoses for cracks and brittleness when you move them. Any leak causes a large loss of performance and economy.
    nick
  1. Quick T-stat replacement question
    By nirvana19 in forum 5 Series BMW
    Last Post: 01-02-2008, 07:24 PM
  2. Quick question**
    By Milkboot in forum 5 Series BMW
    Last Post: 08-28-2007, 11:58 PM
  3. Quick question...anybody ever get...
    By HDhandyman in forum 5 Series BMW
    Last Post: 01-12-2006, 11:55 AM
  4. Quick question
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 07-04-2005, 11:14 AM
  5. Couple of quick question re. 535i radiator replacement
    By Mitch90535im in forum 5 Series BMW
    Last Post: 05-08-2004, 05:28 PM
