Sorry I talk about pedal height but it is height when the pedal is depressed.Originally Posted by rob101
So it is more of a pedal travel. The pedal height is the same.
I need to get my noise back into the Carol book.
A floating caliper is like a two piston caliper isn't it?
I think the piston is being pushed against the pad and the body of the caliper is being pushed the opposite side.
So I do think that the fluid displacement on a floating caliper is twice the displacement of a fix caliper piston.
So the area should be multiplied by 2. (or 4 if you take 2 calipers and 8 for the 4 pot calipers.)
If you want to join the Wiki, we can start doing some calculations in there.
http://bmwe34.wetpaint.com/page/Brakes+mods
Originally Posted by attack eagle
I would love to know what is the pistons size in the 4 pot front and back setup from UUC... I bought some 1.38 for the back but I think it will be to big now... ARG.
Yeah i thought about it last night, and i think i was wrong because the sliding caliper will apply double the force per area of piston because the reaction force of the caliper pressing against the disc will clamp the othersideOriginally Posted by attack eagle
http://www.sportcompactcarweb.com/ed...hno/index.html which is confirmed by this article so there you go....
I would join it if i wasn't at work right now LOL, first thing that pops to mind bruno is that for pedal feel you should be thinking about pedal travel vs. clamping force. it sounds like atm your thinking in terms of the displacement of the pads/pistons rather than their clamping force, clamping force is what determines the braking torque on a certain disc not the actual caliper piston travel. if you get my meaning.Originally Posted by Bruno
jsut reverse engineer the area needed from what is already fitted.Originally Posted by Bruno
figure the area now, x2 for sliders, divide by number of pistons, divide by pi, square root. piston radius.
Based on the 40mm rear you have now, i come up with a 28mm 4 pot.
that is a 1.1"... so arg indeed.
Well, time to sell all my 4 pot callipers and pick up the right ones.
No big deal for the rear anyhow, not a priority anymore.
I need to finishe my A-arms to replace the thrust arm and control arms 1st.
