Hi all.
I recently removed the drivers seat from my car to do the "shortening" of backrest & height cable outers.
When I put the seat back, the "Memory" button doesn't work anymore. The button does not light up when it's pressed and it doesn't store new seat positions. I removed the switch to test it and it seems to work correctly.
Switches 1, 2 & 3 work fine with the settings that were stored previously, but I don't seem to be able to change (re-program) them !
The globe works. (pins 3 & 4 on the memory switch)
The memory switch LED works. (pins 1 & 5 on the memory switch)
Memory switch pushed - 0 ohms between pins 2 & 6 on the memory switch
Switch 3 pushed - 68 ohms between 2 & 6 on the memory switch
Switch 2 pushed - 180 ohms between 2 & 6 on the memory switch
Switch 1 pushed - 550 ohms between 2 & 6 on the memory switch
Reg.
