Results 1 to 10 of 11
Thread: 94 525 after head repair car will not start
    Default 94 525 after head repair car will not start
    i have a 1994 bmw 525 . i bought it knowing it needed head work . i replaced the head gasket put it back together it ran but could tell it was still leaking. pulled head again head was cracked had it welded and rebuilt . put car back together it will not start . the timming marks were lined up # 1 cylinder up . how do i know where to put cam shaft as far as timing goes. i think they are the same as when i pulled them . also when i put the head on the 2ed time i pinched the crank position sensor alittle . the wire looks shielded and that is the part of the wire i pinched the shield and the outer plastic not the main wire so taped it up and went on . does any one have any suggestions?
    thanks pat
    M50, non-vanos below. Cams in are set properly. Cylinder 1 up and toward each other, the tops of the 'squares' at the end of the camshafts (you can kinda see the 'squesres' in the second photo) must be as level with the top of the cylinder head casting as possible. You can use a straight edge if you don't have the special tool.
    No suggestions for the CPS wire. It will let you know if its buggered.
    East Brunswick, New Jersey
    Yours has VANOS but the cam shaft orientations are the same. You may have to rotate the intake cam slightly when you fit the VANOS unit but that's okay.
    At this point you should do a compression test first to make sure you did not accidently disturbed timing and bent the valves.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    i turned the motor by hand befor using the starter . is there still a chance i did some damage . would there be added force or a noise if i did some damage?
    later pat
    Oldham, England
    Quote Originally Posted by lippshitts
    later pat
    If you turned the motor by hand with the plugs out I think you would have felt resistance if pistons and valves were coming together. But there will actually be less resistance if you have got bent valves now-you wont have any compression. As stated already, a compression test will soon tell you. Hopefully all is OK. But if it isnt, and you want to take the cams out, dont just unbolt the caps or the cams will snap like a carrot
    Reading, UK
    Quote Originally Posted by whiskychaser
    Who on earth would think about doing something like that?
    I didn't have any choice yer honour... and it ran afterwards too!
    Default no spark
    i had time to mess with my 525 again found that i dont have any spark . is there a way to check crank position sensor . and could that be the problem .
    thanks pat
    thanks pat
    Yes, you can check it with a multimeter. Specs are in the bentley.
    Also, make sure the camshaft position sensor "tag", which sits behind the intake chain pully and triggers the sensor, is on the right way up. Ask me how I know
    Dave
    Default will not idle
    i changed the crank position sensor and the car starts but it runs rough will not idle. can keep running with foot on gas . please help .
    Reading, UK
    That sounds like your timing is out or you've got a massive vaccuum leak, check for leaks , turn the engine to TDC and then make sure the square lobes at the back of the cams are parallel
  1. Cylinder head repair
    By infurno in forum 5 Series BMW
    Last Post: 11-24-2008, 07:04 PM
  2. Info on rebuilt or repair cylinder head - M50
    By bummininca in forum 5 Series BMW
    Last Post: 03-07-2007, 08:05 PM
  3. A very big THANK YOU ! - head gasket repair.
    By Zeuk in Oz in forum 5 Series BMW
    Last Post: 02-07-2006, 01:26 AM
  4. Ghetto head gasket repair
    By Mr. BILL in forum 5 Series BMW
    Last Post: 03-03-2005, 01:54 AM
  5. changed head gasket~now engine will not start
    By nopce in forum 5 Series BMW
    Last Post: 06-16-2004, 03:51 PM
