Results 1 to 10 of 13
Thread: OEM Radio removal
    Mar 2008
    NY
    Default OEM Radio removal
    Has anyone fashioned a tool to take the radio our or is this something I need to go the dealer for? I'm trying to figure out the code so I can at least listen to some tunes.
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
    2000 Harley Davidson Softail
    2004 Ford Expedition
    Marietta, GA
    All you have to do is open the little doors on either side of the radio and use a hex bit to unscrew it. I don't know exactly what size but I'd say the right one would probably be in a set that you could buy.
    Mar 2008
    NY
    Do you mean a small torx?
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
    Quote Originally Posted by vping
    You've got a Magnette?
    Those are a blast... I used to work restoring MG's and Triumph's.
    did the Magnette have suicide doors or am I thinking of the fiat millecento?
    Robin
    72 Chevy K10
    01 E39 M5
    Nov 2006
    Mid-Atlantic, USA
    Actually, it's a 5-sided hex, not a normal Allen or TorX, but you can usually jam a tiny screwdriver in there and make it work.
    Lexington, Kentucky
    e-bay has radio removal kits for about $20 which includes the BMW radio removal tools as well as Ford , Mercedes, VW and Audi.
    Mar 2008
    NY
    Thanks for the info on the radio removal. Going to try it later. I've gotta get that code now.
    The Magnette is a parts car. I just got it on Saturday and am stripping every nut and bolt to help out other enthusiasts.
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
    I've done it with a metric allen wrench.
    Mar 2004
    Phoenix, AZ
    Default The tool is a five-sided hex (or in this case penta-)style screwdriver....
    You can get one from Bavarian Auto for about $10. I have one and used it mainly to access anything in the upper center console behind the radio. Lot of indys will get your code for you. They have to first get the serial # of the radio off of the back of the unit.
    Did you lose the radio manual that has the code in it?
    JD
    Mar 2008
    NY
    The PO did not give it to me yet. He is still trying to locate all of the paperwork. I only have the Owners Manual. I should be trying to get it out tonight.
    How can I contact these "indys"
    1952 MG TD
    1963 MGB
    1967 MGB GT Special
    1974 MGB Roadster
    1991 Ford Ranger
    1997 BMW 528I
  1. Factory Radio Removal
    By Chris Bowne in forum 5 Series BMW
    Last Post: 10-31-2010, 04:50 PM
  2. Need more help with ICV removal
    By brendanm in forum 5 Series BMW
    Last Post: 01-21-2007, 06:28 AM
  3. Radio lights - source? Not Radio Shack
    By scott 4991 in forum 5 Series BMW
    Last Post: 12-29-2006, 05:55 PM
  4. Cluster removal without steering wheel removal...
    Last Post: 02-18-2006, 04:08 PM
  5. Pentagonal Tool for Radio fitting/removal
    By A1BMW535iSport in forum 5 Series BMW
    Last Post: 11-24-2004, 11:39 AM
