Lift bonnet,(changed the filter lately?) give the glowplugs one burst,turn over and watch clear pipe from filter to pump,if air in it,first change filter,wet seal(check central one is in head) and screw on tight.(fill filter beforehand with fuel treatment and diesel). Give the glowplugs at least five bursts,park the car on the level with at least half a tank, it should go??!! In the above are most of the things that can go wrong,if you have left the car and are in the south UK then you may have "bugs" in the tank,like me.Mine starts first thing warm or very cold but is a bitch otherwise,pump changed and everything bar the tank until I checked the fuel and found it black, cleaned once but forgot lines so its time to do it again.............
