Results 1 to 10 of 15
Thread: Blower Rattles? Prognosis?
    Aug 2006
    The Woodlands, TX
    Quote Originally Posted by Jehu
    Once the Blower (I assume this is what I hear) begins to rattle can this still work indefinitely or do they always fail completely shortly after? Started hearing this a few weeks ago and now its pretty much a full time, all speed rattle... I also tonight believe i noticed the speed was flutucating rather wildly speeding up then slowing...
    Weird, mine has started quitting when the A/C is on and the fan is switched to like the #2 setting. Moving it to the #3 setting it works fine. It doesn't seem to do that with the A/C off so I'm assuming it's somehow related to that, maybe a leak somewhere in the A/C/Heater plumbing somewhere?
    I had a Volvo 240 DL that was noisy the way you describe and it never did fail all the years we owned it, dk about bimmers though.
    May 2006
    NH
    Default Blower Rattles? Prognosis?
    1995 540i Manual build 1/95
    They will go for a long time making noise. If you can stand it.
    May 2006
    NH
    Any idea what's causing the rattle exactly? The impellers just wearing on their axle? Replacing with another used part may not be all that smart if they all end up doing this eventually.
    Aug 2006
    The Woodlands, TX
    With the experience with my Volvo, I think you'll get sick of hearing it and go ahead and fix it long before it completely fails.
    May 2006
    NH
    Quote Originally Posted by dauchande
    Probably true. I am just such a huge wimp when it comes to being uncomfortable driving in the heat that its at least some relief to have some basis to trust i will probably not be forced to go without it due to sudden failure before I get a new one and install it.
    The motor shaft rides in bronze bushings that wear. If the slop becomes bad enough they screech like hell and even sometimes the blower cages rub the housing. I've seen them with .030" play and still turning.
    It will "function" almost indefinately but the noise will eventually get the best of you.
    May 2008
    I have a '93 e34 and my blower started rattling also after a long few winters of storage. I blew the fuse now. I suspect that mice have got in and built a few condos. They always seem to get in this area for some reason. I am going to open it all up today and clean it out. My speed settings work sometimes and then cut out and last time I only had full speed--so for sure I also have to replace the motor resistor blue block--a common failure item. Will know more in a day or so.
    Reading, UK
    Silicone spray usually clears the 'SCREEEEEEE...' noise if the bearings go noisy, however it's only a temp fix and a hell of a lot of work to strip it for a months worth of noise free operation!
    Apr 2005
    Canada
    Ross you say : It will "function" almost indefinately... Upon your experience what about the life of the brush that feed the blower motor ? what's the chance that they fail / worn out before the bushing ?
  1. Rattles
    Last Post: 05-16-2008, 06:26 PM
  2. Sunroof rattles
    Last Post: 12-28-2006, 01:25 AM
  3. Door Rattles
    By Ariel525i in forum 5 Series BMW
    Last Post: 11-28-2006, 08:36 AM
  4. I got the rattles
    By digitaldragon03 in forum 5 Series BMW
    Last Post: 08-20-2005, 06:47 PM
