Thread: Supercharging an E34 535, questions??
    May 2008
    Default Supercharging an E34 535, questions??
    Hi, just joined as I have bought a nice 535i sport E34. I am looking to fit an Eaton supercharger. I only have the S/C not a whole kit.
    My main questions are around engine management. I am reluctant to use an aftermarket ecu unless there is a cheap option. Can i use the original ECU, if so, how do i control fueling and timing?
    Any help would be appreciated.
    baton rouge, loserana
    if you can solder proficiently you can build a megasquirt computer to run it on for maybe $4-500 for everything (the ms unit a wide band 02 sensor and the adapter), a guy developed a adapter board to hook into the stock harness plug so it's nearly plug and play
    ps you will need other things like bigger injectors to run boost but you could run the motor on the ms with all of the stock stuff to get everything up and running then build the blower
    Honolulu
    Search on Redfive and see what you get.
    Bellevue WA
    86 Porsche 951 - Track Toy
    May 2008
    thanks, whats redfive and do you mean search on the web or the forum. not much comes up on the forum.
    try this. Jason, Redfive Racing, One Lap both here and on the web. He was a poster a while ago that did a lot of work to fit a supercharger on his E34. While he got it to work, I recall he gernaded the engine due to fueling problems.
    Bellevue WA
  1. Replies: 6
    Last Post: 04-14-2006, 06:54 AM
  2. supercharging question
    By bullyd in forum 5 Series BMW
    Last Post: 01-09-2006, 06:42 PM
  3. Supercharging-Have to read this!
    By 93-525i in forum 5 Series BMW
    Last Post: 10-02-2005, 07:28 PM
  4. Tech Info : Supercharging
    By stx133 in forum 5 Series BMW
    Last Post: 08-22-2005, 07:30 PM
  5. a/t questions
    By tnt525i in forum 5 Series BMW
    Last Post: 06-18-2004, 04:56 PM
