Results 1 to 10 of 14
Thread: I ordered the Korman offset adjustable cam gear.
    Default I ordered the Korman offset adjustable cam gear.
    We'll see if dialing the cam on an internally stock m30 helps. It is machined for 1,3,5,& 7 degrees of offset. Will there be a noticeable difference with 1 degree of advance?
    As an aside, I had the car buffed out yesterday. It is spectacular. There was a little tree sap incident before the trip to Hawaii. It has been on my mind & now it is good.
    erased due to slander
    Meridian, ID
    What did the sales people say at Korman? I have pretty much the same options/mods as you list and would be interested in what this does. I'm also considering the MAF and boring out the throttle body.
    Keep us posted.
    Mike Holbrook
    Meridian, Idaho
    Renton, WA
    Won't it pretty much just move your powerband around?
    1992 535i TCD-s2
    Default How much work is it to install one of those?
    Can you do it with the head on or do you have to pull some head bolts to get the cam shaft off?
    Robin
    72 Chevy K10
    01 E39 M5
    Default Alan suggested that he hadn't heard of anyone doing this on a stock, uncut head.
    He then went into how all the performance stuff that sells, was for the 3's. We discussed the ceramic coated exhaust headers they had. Korman didn't have any in stock & I didn't have a spare set to send. He then mentioned the earlier m30's would benefit from their gasket matching port job. He said the b35m30 manifolds were pretty good stock. They had no headers available for our cars.
    The maf is good. Look into it, especially if there is a local dyno available for setting it up.
    Quote Originally Posted by mholbrook
    Keep us posted.
    Default The cam stays in. Just pull the thermostat & upper timing cover to change the cam ge
    Your bee motor may already have the cam advanced. Derek bought it as a complete motor, I believe.
    Quote Originally Posted by Robin-535im
    Yup. We have hearsay reports that the stock M30 likes 2 degrees of advance. The only way to know for sure is to try it.
    Advancing the cam in theory trades some top end for low end.
    Quote Originally Posted by Craig
    Bellevue WA
    86 Porsche 951 - Track Toy
    I don't think Derek modded the cam timing, I sent him a note asking him. How's the midrange vs. the topend Robin? If you want more midrange punch, it might be worth trying. Of course, with that 3.91 rear end, your gears may pretty much compensate for any soft midrange.
    Bellevue WA
    Default Interestingly, with the EAT chip instead of the TMS,
    the power band is smoother. Now is it higher where it used to be low or lower where it used to be high? My kester isn't sensitive enough to tell.
    It definitely still feels fatter in the mid range than stock, and I'd be interested in pushing the power band up by 1000 - 1500 RPM if possible so that the pull lasts higher into the gear.
    How much do one of these adjustable cams cost?
    Quote Originally Posted by Jeff N.
    Robin
    72 Chevy K10
    01 E39 M5
    Meridian, ID
    Wouldn't advancing the cam by x degrees (1, 3, 5 etc) push the power band up therefore giving less torque at the bottom end? Conversely retarding the cam would give more torque sacrificing top end power?
    This is the first I've heard that the M30 liked a couple degrees more advance. I know the Mopars liked that small advance and it is provided by a different crank key.
    I have my car really running great right now but I'd really like more torque down low. I don't mind shifting at 6500 or even less. It will pull to almost 7000rpm indicated before I back out. It has a TMS chip.
    This is interesting.
    Mike Holbrook
    Meridian, Idaho
  1. Korman Cams
    By acidfire52 in forum 5 Series BMW
    Last Post: 11-21-2006, 07:10 PM
  2. 525 with m3 engine for street/track: Korman
    Last Post: 10-02-2005, 04:47 PM
  3. Received the Korman adjustable cam gear.
    By Martin in Bellevue in forum 5 Series BMW
    Last Post: 06-10-2004, 07:49 PM
  4. Korman / mosselman turbo setups?
    By bahnstormer in forum 5 Series BMW
    Last Post: 05-23-2004, 02:16 PM
  5. Just ordered from BMA..
    By ilya in forum 5 Series BMW
    Last Post: 02-24-2004, 10:05 PM
