Results 1 to 8 of 8
Thread: intermitten rubbing noise from right rear wheel, sticking caliper
    Dec 2006
    Default intermitten rubbing noise from right rear wheel, sticking caliper
    I have a rubbing / grindy noise every once in a while from my right rear wheel. I am thinking caliper, since that would explain why it is intermittent. Any tips or tricks to get it unstuck?
    Dec 2006
    no one has any ideas? Stock tire, stock wheels. lowered 1 inch on eibach springs, bilstein sport shocks. When I first drive the car in the morning, no noise. Then, if I drive it an hour or 2 later, the rubbing noise starts. What could it be? Nothing visually obvious that I can tell....
    Benneton (United Colors of)
    it would most likely be a caliper pin that has gone out of round/out of lube rather than a caliper sticking. after a long drive, feel the brake hardware on both sides of the axle. if one side is hotter than the other, you probably have an actual stick. also, pin problems will manifest themselves as pads that wear down at an angle abnormally faster compared to the other side, as opposed to the wholesale overheating/wear situation that occurs for a sticking caliper.
    Dec 2006
    thanks ryan, I appreciate the advice.
    Mar 2007
    Liverpool UK
    Hey, I'm interested in this one as I seem to have a similar problem (I don't want to hijack the thread but It seems like we're in the same boat!). I don't have an audible noise when driving but when I jacked the car up the other day the front wheel was not turning freely when I spun it by hand. I could hear the brake pad rubbing on the disc. Brakes discs and pads are probably less than a year old and fitted correctly... Pins etc seem to be fine too and wear is even on discs and pads (lots of pad left). I've been thinking performance isn't as good as it used to be - could I have a problem? Anyone?!
    Repent - have you tried spinning yours by hand?
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Dec 2006
    Quote Originally Posted by e34.535i.sport View Post
    that is the next step once I have some time to get under the car. I am going to give it a shot hopefully next week or this weekend if work slows down. I will also take the wheel off and examine the caliper assembly.
    Dec 2006
    ok - i'm moving to another country this weekend, so i don't; have time to fix this until next eek. it's still making the noise, but it drives fine. what is the worst case scenario if the caliper really is sticking, and if i drove it 400 miles in one shot? is there a super quick way to alleviate the symptoms until i can replace the caliper or caliper pin?
    Feb 2008
    Quote Originally Posted by repenttokyo View Post
    good luck with your move ben, if you want a hand with the car before give a shout.
    you know how much i know but could your problem just be a bad spot on the brakes? i get the occasional bit of rub and it's just a couple of tiny tiny spots of rust towards the outside of the disc. happens after it has sat tho. i never thought it was a big deal i hope someone corrects me if it is.
  1. Rubbing Noise in my steering wheel
    By Ted K in forum 5 Series BMW
    Last Post: 10-05-2008, 07:50 PM
  2. Rubbing noise from rear of 520i
    By GarethHart in forum 5 Series BMW
    Last Post: 06-02-2008, 01:15 PM
  3. Replies: 21
    Last Post: 07-10-2007, 08:52 AM
  4. Replies: 14
    Last Post: 12-19-2006, 07:25 PM
  5. sticking rear caliper
    By RIPN RAY in forum 5 Series BMW
    Last Post: 07-05-2006, 10:46 PM
