Results 1 to 10 of 13
Thread: power steering
    Jun 2008
    south africa
    Default power steering
    hi guys can someone help me because when i turn my steering wheel there a ringing noise or squeeky noise the power steering pump was changed but the noise is still there
    Great Britain
    In some (or maybe all?) models there is a filter in the reservoir for the power steering fluid. It might be worth changing the filter and fluid. You can find out whether you've got a filter from realoem (do a search on this forum) or your dealer.
    Quote Originally Posted by pingu
    New ZF resorvoirs with the new filter in them are $20-$25. Easy swap-but do the fluid by the book too- you have todrain from the lowest point.. I use the Castrol Synthetic Dexron replacement- just cos it uses so little and I can leave it and not worry again.
    The noise is from cavitation, you need to bleed the air out, or rebild the pump or fix the connetion to it if its ben bodgied by the PO (this takes care)
    I have complete overhauled my power steering pump, no more noise, very gentle power steering now. Just the gaskets, seal on the shaft and the 2 profile rings on the impeller.
    Jun 2008
    south africa
    Default thanks guy
    Quote Originally Posted by pingu View Post
    i will check if i have a filter
    Please add to your profile the complete model and engine plus month and year of production, helps us a lot to help you.
    VIN decoder is on my website below where you find these details.
    Jun 2008
    south africa
    what.website.should.i.go.sorrrrry.my.kid.just.brok e.my.space.bar
    Jun 2008
    south africa
    thanks.can.you.tell.me.wat.could.be.the.cause.of.m y.car.not.starting.on.the.turn.of.the.key.
    first fix your PC, then the car ;-)
    What car is it, manufacturing year etc.
    Does the engine crank? Or nothing at all when you turn the ignition key?
    You have to tell us more so that we can help you.
    What have you checked so far? Ignition, spark plugs, fuel pump/delivery system and so on.
  1. Power steering cut out
    By stx133 in forum 5 Series BMW
    Last Post: 08-19-2009, 06:41 AM
  2. Power Steering
    By PLATINUM in forum 3 Series BMW
    Last Post: 09-02-2008, 09:28 AM
  3. Power Steering Help!
    By realness in forum 5 Series BMW
    Last Post: 04-01-2008, 02:52 PM
  4. Power Steering
    By 94_e34_525i in forum 5 Series BMW
    Last Post: 07-04-2006, 05:32 PM
  5. Replies: 10
    Last Post: 02-01-2005, 01:25 PM
