Results 1 to 10 of 14
Thread: #@~$%*^ £&#@! Clutch slipping.
    Reading, UK
    Default #@~$%*^ £&#@! Clutch slipping.
    Ok, so you help someone and get shat on for doing it by karma, I think towing back that other E34 has finished off my clutch.
    Is the clutch pedal/etc adjustable at all? It's got to the point where it's minorly slipping, you just have to touch the clutch pedal (and I mean literally just touch) and it lets go.
    Thing is, it was replaced 18-24 months ago...
    Any thoughts gents?
    Reading, UK
    I should clarify this - the clutch is letting go when the car's cold most of the time.
    After the car's warmed up the clutch grips normally - rather than the normal clutch failure routine, this actually feels like the clutch pedal isnt retracting properly.
    I find it very hard to believe that it's worn down completely in less than 2 years!
    Nov 2006
    Germany
    Quote Originally Posted by Ferret View Post
    This is a hydraulic clutch, right? If so, your symptoms are the reverse of a poorly-adjusted clutch pedal push rod. As in, adjusted to be too long, which closes off the hole to either the reservoir or the pressure line to the slave when hot and builds pressure on the slave, releasing the pressure plate some and causing clutch slippage.
    I take it the clutch starts engaging somewhere near the floor with a normal 'bite' range. I doubt it as you say that damn-near breathing on the pedal makes the clutch slip. So, either the friction disk is toast and/or the pressure plate has lost its spring or the whole rig is out of spec.
    Did you have the flywheel ground during the last clutch job? If the machine shop failed to resurface both the friction area and the pressure plate mounting area then the flywheel is not at factory specs...and set this clutch up to fail early.
    Brian
    Oldham, England
    Quote Originally Posted by bsell View Post
    Brian
    x1
    Or its burnt out or got oil on the friction plate. I dont have a manual but doesnt the slave cylinder drop clutch fluid into the bell housing if it leaks?
    Reading, UK
    Quote Originally Posted by whiskychaser View Post
    x1
    Guys, the clutch starts to engage half way up the pedal travel, and has a 'bite' point that's half the travel range!
    Any ideas?
    Reading, UK
    Okay, very strange, posting just got screwed up on this site...
    Reading, UK
    The clutch releases with less than 10mm travel on the pedal, I'd call that "damn-near breathing on the pedal makes the clutch slip."
    It starts to bite half way up the pedal travel though, I'm starting to think the friction disk may be glazed.
    Nov 2006
    Germany
    This sounds like the disc is warped from the heat of slipping. The warpage tends to hide how much friction material is missing by taking up the space left behind by the missing friction material. Does that sentence make sense?
    In other words, the warpage gives some bite near the normal engagement point yet can't stand any pressure reduction without slipping.
    Did you get the flywheel ground to remove hot spots during the last clutch job? If you do it this time around, make sure the machine shop gets it right. I don't have the specs for the flywheel but somebody around here probably does...
    Brian
    Oldham, England
    Any ideas?
    You only get about half an inch of bite on an HGV so something isnt right. Any chance the release bearing is jamming and not allowing the clutch to return properly? They are only held on to the lever with a wire clip but its unusual for one to slip. Never known anybody have to replace the lever itself. Well, until last week when I saw somebody buy one at my local BM dealers. Is it worth having a look at how much travel you have got on the lever?
    Wellington,New Zealand
    does the 540 have a dual mass flywheel?I have heard that they cant(shouldnt) be machined.
    Gone but not forgotten
  1. clutch slipping
    By pheno in forum 5 Series BMW
    Last Post: 05-06-2007, 09:28 AM
  2. Automatic slipping
    By Denasti in forum 5 Series BMW
    Last Post: 07-25-2006, 05:51 PM
  3. 1995 M3- Clutch Slipping? ADVICE NEEDED!
    By SF E36 in forum 3 Series BMW
    Last Post: 06-07-2006, 09:08 PM
  4. Replies: 3
    Last Post: 09-26-2005, 01:07 PM
  5. A slipping clutch, or??
    By DallasBill in forum 5 Series BMW
    Last Post: 07-10-2004, 11:15 AM
