Results 1 to 7 of 7
Thread: Questions about Climate Control
    May 2008
    Oregon
    Default Questions about Climate Control
    I have a 1995 525 which i purchased in April and ever since i bought it i have noticed that the dual climate does not work. My question is, since mine was the base model (without cold weather package and leather, etc.), was the dual climate an option? I have a knob but it seems to be fake. Another question....No matter how much hot air blows out of the front vents, the rear seat vent in the center console only blows out cold air. Is this normal or is there something wrong?
    Wellington,New Zealand
    Quote Originally Posted by BMW_Noob View Post
    rear centre vent will only ever be fresh outside air
    Not sure what you mean about fake knob
    Gone but not forgotten
    El Paso TX
    sounds liek the control panel is fubar???
    May 2008
    Oregon
    Quote Originally Posted by Paul in NZ View Post
    I guess im just used to the new cars where you can change the temperature of the rear seats. What i mean by fake is that the left one kind of clicks or locks into place at the hot/cold ends but the right knob just moves from side to side without that. Also, when i try to make the right side one temp and my side another, they always feel the same (either hot or cold).
    El Paso TX
    Left side has "override" which is the detents on either end. If your left side is in the full cold detent position, then no, you won;t get hot air on the other.
    Jan 2008
    UK
    Your knob might not be a fake afterall!!!!! (no pun intended!!) On my e34 the right handside knob clicks into place at it's furthest clockwise travel so when i turn it all the way to 'hot' it clicks into place, but the left handside one just turns round.....i have aften wondered about this actually!!! Both these knobs are electrical, i.e they dont have cables attached to the heater matrix as you would expect.
    Hope this helps in some way.
    the whole idea of seperate temperatures side to side is kinda lame when you are sitting in the same 1.8 m of space.However I can get different output temps from one side to another.As already mentioned dont operate the drivers side at absolute max hot or cold,this overides the whole system to hot or cold
  1. Climate Control
    By Jerry Neri in forum 5 Series BMW
    Last Post: 05-16-2009, 07:18 PM
  2. 92 735 climate control
    By Visions in forum 7 Series BMW
    Last Post: 10-27-2006, 07:07 PM
  3. no air from climate control
    By tpierce in forum 5 Series BMW
    Last Post: 06-05-2006, 03:32 AM
  4. Replies: 4
    Last Post: 01-04-2006, 02:11 PM
  5. Auto climate control
    By Mike in forum 5 Series BMW
    Last Post: 03-02-2004, 01:31 AM
