Jeff, how are your back tires? I ask because I was getting what I thought were driveline vibrations, swapped by Guibo and center bearing, still no change, then changed the rear tires...they were due. Problem solved. CB needed it anyway, but the guibo was probably not required. The rear tires didn't look bad, but the thing is smooth as glass now at speed!
Cheers
Duey
