Results 1 to 5 of 5
Thread: 95 540i engine tick
    Klaus Schuller Guest
    Default 95 540i engine tick
    When I bought this car at 60,000 with a fairly new engine due to nikasil problem the engine had a slight tick. Sounds like a valve tick but I believe this car has hydrolic valves. I thought this was normal, but I did not have the oportunity to compare it to another 540i. Now at 90,000 the tick is louder. Is this normal??
    No tick is normal... have you changed the belts? Sometime it is the belt that causes ticking noises.
    Tampa Bay, Florida, USA
    I had a ticking sound that was rpm related. My indy dumped some stuff called Wonder Oil into the AC system. It's gone now.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Unregistered Guest
    Default Check for a loose spark plug
    A loose plug will also make a ticking sound that increases in frequency with increasing RPM.
    Mike
    so will an exhaust leak or a leaky injector.
  1. E34 M50 Tick Tick Tick Tick Tick... Help!
    By wishihad50k in forum 5 Series BMW
    Last Post: 09-12-2011, 09:07 AM
  2. Tick over / battery ?
    By jrgibb in forum 5 Series BMW
    Last Post: 11-24-2006, 04:23 PM
  3. tick over probs
    By wappy in forum 5 Series BMW
    Last Post: 07-20-2006, 03:15 PM
  4. Bottom end tick. Possible oil pump?
    By Felixdacat in forum 5 Series BMW
    Last Post: 05-04-2006, 03:12 AM
  5. Tick-tick- tick noise when AC running-cause?
    Last Post: 05-09-2005, 08:27 AM
