Had the exact same issue. I let the car run for over an hour, no sign of heat. I put a long screw driver to the AUX pump to verify that it works. Since my car wasn't overheating, I took it for a spin. Once the RPM's went up, heat came into the cabin. I had to do this two times before I got all the air out. Give it a try, since you have a manual transmission you can just rev the engine.
