Results 1 to 5 of 5
Thread: M30 intake manifold and oil cannisters.
    indiana
    Default M30 intake manifold and oil cannisters.
    Does any body want/need an intake manifold from an 1989 E32/M30. It has the fuel rail on it. I have two M30 oil cannisters with the shot the check valve. If you want to fix it then swap it out with your broken oil cannister, let me know. Or if you want to just get the lid powercoated.
    Joe
    Unregistered Guest
    Quote Originally Posted by JoeS
    Joe
    what do you want to have for the intake manifold and fuel rail?
    where do you live?
    greets Bas 530 (m30)
    -JoeS Guest
    Default M30 intake
    Shot me an email with an offer. jjjoeee@insightbb.com
    North Central indiana .
    Bay Area, CA
    Do the oil canisters fix the problem described on www.bmwe34.net? If so, I'm interested? What are you asking?
    (http://www.bmwe34.net/e34main/trouble/OilCanister.htm)
    -JoeS Guest
    Default M30 oil cannister
    As stated in the initial post - they are shot and the check valve needs to repaired/replaced. So no - they are not the instant cure to the failing cannister problem, but I believe Bruno has the fix posted on bmwe34.net. You could fix it , then replace your old one.
    Quote Originally Posted by E34N
  1. m50 intake manifold
    By shadowpuck in forum 5 Series BMW
    Last Post: 03-09-2008, 12:39 PM
  2. intake manifold
    Last Post: 03-06-2006, 11:40 AM
  3. anyone want a v8 intake manifold - used???
    Last Post: 01-08-2005, 08:49 PM
  4. Intake Manifold
    By jj7 in forum 5 Series BMW
    Last Post: 11-28-2004, 12:18 PM
  5. Why would there be oil in the intake manifold?
    By Anton CH. in forum Engine & Drivetrain
    Last Post: 02-14-2004, 09:12 PM
