Results 1 to 7 of 7
Thread: How can a M50B20 be changed to M50B25?
    Apr 2008
    Belgium
    Default How can a M50B20 be changed to M50B25?
    This is a noob question, but I have found a very low mileage E36 320 and I'm thinking about buying it and taking its engine out and bring the 50k engine to my favorite chassis, the E34.
    Could I do something to make the engine a 2.5 liter?
    thank you.
    Aug 2008
    Pennsylvania
    From what I know you will have to bore the cylinders out to make it a 2.5L. I am not sure about the head.
    Apr 2008
    Belgium
    Quote Originally Posted by russiankid View Post
    ok forget it that's already not worth it. I might as well just find a M50B25.
    Oldham, England
    Quote Originally Posted by Mordan View Post
    thank you.
    To increase engine capacity isnt really that simple. You are talking larger cylinders and pistons. Probably different con-rod lengths. Maybe even different crank, valves and cams. When you are looking at spending used engine type money it really isnt an option. If you have a 2.5 already I'd say spend the money on doing that one up or buy a recon. You at least sure its going to function with the fuel/ignition systems that are in the car
    Edit: Seems my post was ill-timed and is redundant
    Apr 2008
    Belgium
    Quote Originally Posted by whiskychaser View Post
    well dunno why but from the clouds of my memory, one BMW seller told me one day, something about the pistons (was it something else?) was common among many BMW engines.
    does that strike a cord?
    Just speculation; I'll guess the block is a different casting between 2 and 2.5, the 2.0 cylinder walls won't be thick enough for the overbore.
    Oldham, England
    I stopped being lazy and looked it up: The 2.0 and 2.5 have different bores and strokes: http://en.wikipedia.org/wiki/BMW_M50
    And I'm pretty sure the head is different ( Ferret can confirm-IIRC he put an 2.0 on a 2.5 - until it blew up)
    I'm sure Ross is right about boring out. There might be some common parts but I cant think of any right now
  1. oilfilter housing and CCM for sale for 525i M50B25 vanos
    By werminghausen in forum 5 Series BMW
    Last Post: 11-25-2009, 01:28 PM
  2. m5 diff on e34 m50b25
    By filip00 in forum 5 Series BMW
    Last Post: 02-04-2007, 01:40 PM
  3. M50b20 -> M50b25
    By Joda in forum 5 Series BMW
    Last Post: 09-11-2006, 12:20 PM
  4. m50b25 valve timing help
    By duke in forum 5 Series BMW
    Last Post: 01-03-2006, 04:26 PM
  5. '91 e34 M50B20 engine without o2 sensor!?
    By molesz in forum 5 Series BMW
    Last Post: 05-04-2004, 10:00 AM
