Results 1 to 5 of 5
Thread: Torque for crankshaft bearing bolts?
    Default Torque for crankshaft bearing bolts?
    M30 engine 535ia: What is correct torque setting for the main bearings on the crankshaft?
    I have the oil pan off and want to make sure the bearing bolts are properly torqued before closing the engine. Bentley does not say.
    Dash01
    '90 535ia 272K miles
    Jan 2008
    Quebec, Canada
    1990 535ia: (from Mitchell on Demand)
    Main Bearing Caps: 42-45 ft.lbs. (N.m.:58-62)
    BMW E34 1992 525i Touring
    Honolulu
    From Haynes
    Torque wrench settings Nm
    Main bearing cap-to-engine block bolts*
    M10, M20 and M30 engines . . . . . . . . . . . . . . . . . 60
    man thats weak, i remember 100-150lbs being standard... thank god I havent had to rip into one of these yet. would make cheese out of the threads.
    Quote Originally Posted by Blitzkrieg Bob View Post
    From Haynes
    Honolulu
    All you'd hear is SNAP...
  1. Torque on rocker cover bolts
    By mamilapon in forum 5 Series BMW
    Last Post: 04-08-2007, 07:31 AM
  2. M30 535ia Crankshaft bearing replacement
    Last Post: 01-05-2007, 06:48 PM
  3. Torque to be applied on Metric bolts
    Last Post: 11-13-2006, 12:38 PM
  4. What's the torque setting for the 10mm bolts holding...
    By darren540i6 in forum 5 Series BMW
    Last Post: 07-05-2006, 11:14 PM
  5. re-torque head bolts
    By 4byr in forum 5 Series BMW
    Last Post: 04-19-2004, 03:13 PM
