Results 1 to 10 of 10
Thread: A different wheel spacer, ?'s.
    Sep 2008
    Default A different wheel spacer, ?'s.
    I know spacers are frowned upon, but I would really like to run a couple of sets of rims that I have. My 91 535i is not going to see a track any time some and will rarely see more than 80mph.
    Now I have quite a few rims for another car I own. I am planning on making some spacers to fit these rims. Planning on making them hub centric on both faces. Bolt the spacer to the hub, and have studs come from the back side to bolt the wheel down.
    I have a couple of questions:
    1, Stock rims are 8.5 with a et15?
    2, Stock center bore is 72.5 mm?
    3, stock bolt pattern is 5x120? (pretty sure I know this one)
    4, what is the thread pitch and size of the stock lug bolt?
    The average rim I am planning on using is 8.5 with a et38 (9.5 et40) and a 5x114.5 bolt pattern.
    If I am thinking correctly I need to make a 20-23mm spacer (.787-.905)
    I also will be making the spacer to use the 5x114.5 bolt pattern. This will allow me to use many stock and aftermarket Japanese wheels.
    Thanks for looking
    Brandon
    PS. if any one is interested in a set, I could make them at the same time. I will be using a CNC to make these so a couple of extra sets would not be hard. I just want to state that I will not be selling many of these, this is not a group buy or anything like that. I am not vendor on this site and will not be making much money of these couple sets, more so to offset the tooling costs involved.
    Wellington,New Zealand
    Quote Originally Posted by oorx7 View Post
    Thanks for looking
    Brandon
    stock offset is 20,centre hub is 72.5,and yes bolt pattern is 5x120
    Gone but not forgotten
    Sep 2008
    Quote Originally Posted by Paul in NZ View Post
    Thanks! what offset do you have on your BBS's and do you have a 3/4 shots that would show how they fit?
    Jan 2008
    Quebec, Canada
    I don't know how much your cost is going to be, but you might want to look into these:
    http://cgi.ebay.ca/PAIR-WHEELS-SPACE...QQcmdZViewItem
    These are the ones I had on my E34 with the wheels you see in my sig.
    BMW E34 1992 525i Touring
    Nice looking spacers! Those I wouldnt be afraid to run.
    Jan 2008
    Quebec, Canada
    They gave the car a much wider stance and much more stabilty, but I also felt the rotors shimmy alot more than before...then I change the rotors to drilled and that problem went away.
    my bbs are 17x8.5 with 15mm offset,and sit noticebly more outboard than the 17x8 with 20mm offset--best pic i can find that shows how they sit,not my car,previous owner
    Sep 2008
    Quote Originally Posted by bad_manners_god View Post
    Thanks, great info.
    I think that 1.250 will be a little to much for the rims I want to run. But that is a cheap price, probably cheaper than I can piece the parts together and material.
    most of the spacers I have searched for are around a $100 a pair. I know I can make them for cheaper than that.
    Sep 2008
    I can't seem to see the pic. I cut and pasted the url and must need to be a member. Any other way you could post it.
    Feb 2007
    http://www.turnermotorsport.com/html...CT_ID=50757252
    I use the e34 version of these (30mm), so I can fit the e46 m3 wheels. These are very strong, plus pretty light, and they come with some sort of alloy lug nuts
  1. Replies: 5
    Last Post: 12-18-2006, 10:18 PM
  2. What Spacer for e34 rear wheel.
    By sjmst in forum 5 Series BMW
    Last Post: 10-03-2006, 01:26 PM
  3. Recommended 18" Tyre and Spacer Sizes for E34
    By ronkovic in forum 5 Series BMW
    Last Post: 08-23-2006, 07:48 AM
  4. Clickin noise from wheel/lumping in steering wheel
    By m5james in forum 7 Series BMW
    Last Post: 11-19-2005, 11:26 PM
  5. drivers wheel moves backward in the wheel well
    By PhilipJCaputo in forum 5 Series BMW
    Last Post: 10-17-2005, 11:42 AM
