Nope they should be the same, but check that the plug on the headlamp levelling motor (if applicable) is the same.
HTH,
Shaun M
I found these excellent condition headlights for my touring locally, would they fit in my car or does the touring use different headlights?
HTH,
Shaun M
The Touring only has different tail lights. All lights on the front end of the car are the same.
Took my old headlights out of my M-Sport when I bought brand new ones and put them into a friends '95 525iT. There's nothing different about them at all...
Oh, and be aware that unless you're replacing the entire light assembly on each side as one piece you'll need to get replacement bushings (#7 here http://www.realoem.com/bmw/showparts...80&hg=63&fg=05) as they break very easily when you try to pull the lights out of the mounts. Some of them were already broke before I even tried to pull the lights out. You'll need 3 per light, 12 total if you do both of the high & low beams on each side.
Thank you all, it is a complete assembly on each side. I better buy them before he sells them to someone else.
