Results 1 to 10 of 15
Thread: Behr sucks big time- just venting
    Default Behr sucks big time- just venting
    Hi all. I have a '93 525i 5-spd, M50 VANOS, 114K on it, very well maintained and, in my opinion, it's a POS.
    Kind of joking on the last part. In all fairness I've had the car 7 years and 45 thousand miles and overall it really has been pretty good to me. Well, a few months ago the trans gave up the ghost at 113K (yeah, I guess we all learn in hindsight that the Getrag is disposable sh*t and today I learn that I am putting the FIFTH radiator (previous owner did two, and this is my third.) To say I am pissed at Behr doesn't even begin to capture it, but then again this puts my two month bill on this car at around 2,500, so I'm a little biased as that exceeds it's value. Still, DISPOSABLE PLASTIC RADIATORS were a stupid idea to begin with, and the think tank that is BMW should have realized this.
    Car looks like new, it's been immaculately maintained, blah. blah, blah but still my '93 Civic w/ 165 K (original clutch, trans, and radiator mind you) blows it away- reliability wise (well, and tightness wise.)
    I still love the e34- it's an absolutely beautiful machine. It's just disappojnting that a car that's been so well cared for is falling apart at 114K.
    I appreciate the opportunity to vent- that's all I really wanted to do. Just releasing some frustration as I realize my two month bill could have gone a long way towards another (real) car. My real frustration is directed at Behr for making a total POS unit.
    Best to all of you though- this forum has always been a great source of information and I appreciate it a great, great deal.
    Eric
    Lexington, Kentucky
    Yep cooling systems on the e34 are junk. Try a different brand of radiator. Nissens is what I just installed in my car per the recommendation of my mechanic. He said that Behr radiators just do not hold up as well.
    Sep 2007
    Seattle, WA
    Why not put an all aluminum radiator in it instead of dropping more plastic rads in it? You've got a few different choices as far as I'm aware for the M50. VAC, IE, Zionsville, and a few others I think.
    What's been crapping out on the rads?
    Default Da*n Bubba- wish I'd have checked w/ you guys 1st.
    I went ahead and went w/ the Behr this morning, and should have researched this I'll grant.
    The last couple of times they let me supply the part, so it was pretty cheap. I'd bought the Behr for like 160 and felt lucky. This one is costing me 370. I figured I pretty much had to cave as this shop is THE best (I drive an hour to get there) and they've let me supply parts in the past (radiators, suspension upgrade, even the transmission)- they're allowed me to save a bundle. Well, the last visit before this was the transmission, and while they let me supply the trans he politely said they can't keep letting me supply parts so I didn't push it on this one (though I did throw it out that I could get it a he*l of a lot cheaper...he didn't bite ) Oh well...wish it was easier to find a great trustworthy mechanic that allows customer supplied parts.
    I won't kick my a*s over getting another Behr. Apparently they're good for about 23K miles (geez, sounds stupid but I have the records to prove it) and in another 23K this car will either a.) be long gone, sold to some poor sod or b.) simply have decomposed in spite of routine and above average maintenance. Now if I do miraculously begin to feel the love again (don't see that happening, it's like finding out your lovely wife is a f'ing psychopath...you never really see her the same) then maybe I'll keep on rolling (I only put about 1,000 to 1,500 K on per year, so this Behr should last about another 15 years at that rate...and I KNOW the bleedin' car will have decomposed by that time!)
    Default Oh- what's been crapping out...didn't answer
    Sorry about that. 2 things: the Great Repeater is the expansion tank itself...seems prone to cracking. The other issue is the upper neck- those break off spectacularly. There's also the join where the expansion tank mates to the radiator...some say that o-ring can be replaced, but I've never bothered to try (as back then the shop was letting me supply the radiator, and they're cheap if you buy them direct.)
    Again, I don't mean to rag on BMW/e-34's (I wouldn't have kept it seven years of I didn't feel some love) but man I've had numerous other cars way past 114K w/ no issues to speak of (the old Honda previously mentioned, and three Audi Quattros w/out fail that went far above this mileage.) I used to not fear cars over 100K, but I sure do now.
    When you get your car back... let it cool down or slowly release the radiator cap... loosen up the upper radiator clamp until it it free... then tighten it down until it contact the hose and snug that you can still turn it... then snug it down 2 full turn or if it get real tight... then stop.
    Basically you want the hose to be tight but not squeezing the upper radiator neck so tight that will crack it. Get it? I think the biggest reason is people clamped down the radiator neck too tight and upon numerous expansion and contraction... the neck breaks.
    Do the bottom neck also. Then start up the car and let it runs... build pressure and check for leak.
    Jun 2006
    Bethesda, MD
    hmm well-maintained 93 525i 5-speed low mileage. Yeah you're right that cars about to die, better get rid of it quick. Hell, since I'm a generous guy I"ll take it off your hands for you
    Just kidding of course, sorry to hear that you've been having a bad time with the car. I wouldn't call the future owner a sob.. if the car really is well-maintained and the cooling system is the only recurring problem (transmission is unfortunate, but if that was properly fixed as it sounds like it was it shouldn't be a problem for quite some time) it would actually be a great car for someone not depending on a mechanic to do all the work (not to say theres anything wrong with that, but I can imagine it would be quite painful paying the same labor rates charged for fixing cars worth 20x your E34). If you had to deal with all the issues I do with my car you (as most sane people) would probably have shot yourself in the foot by now.
    G'luck and hopefully your car will treat you well for as long as you continue to have it!
    May 2006
    NH
    45,000 miles in 7 years huh? You're gonna drive that thing into the ground aren't you?
    I put as many miles again (130,000) on this car in the past two and half years that it drove in its first 11... my (Behr) rad is Rad! Sorry to hear about the grief...
    1995 540i Manual build 1/95
    MAybe the Behr isn't a sgood as the Nissens on M50s due to the integrated expansion tank. My Nissens has been solid for the last 5 years. As for the tranny, the manual Getrag puked after only 114k? Interesting...... What went? Not that it matters, but my ZF 310 has 300+k without a sign of trouble.
    Curious,
    Dave
    El Paso TX
    meh I jsut put another behr in mine.
    193K and I can not seem to find any reciept for one before, though It might be the 3rd as the neck was repaired. I seriously doubt it though.
    I hurt the previous one when removing the atf cooler lines.
    that being said, no way in hell would I buy a zionsville for an m50... Near 1000 because you have to buy the fan, shroud and all that other jazz as a kit instead of just a rad.
  1. venting about Tire Rack
    By BennyM in forum 5 Series BMW
    Last Post: 01-04-2011, 05:12 PM
  2. nissen va behr
    By dolfan13 in forum 5 Series BMW
    Last Post: 03-16-2007, 10:54 AM
  3. A sad week for Stef. [some therapeutical venting]
    By mzarifkar in forum 5 Series BMW
    Last Post: 01-15-2006, 03:25 PM
  4. nissens vs. behr.....which should i buy?.........
    Last Post: 12-02-2005, 08:18 PM
  5. Replies: 26
    Last Post: 04-29-2005, 01:39 AM
