Reinstalling rear lock actuator
After replacing the rear passenger lock actuator, I've reinstalled the whole lock mechanism. Before replacing the door panel, I decided to test all the connections by hand. The power window controls work fine. Pulling the rod that is tied to the locking pin causes the door to lock correctly. I can open the door from the outside handle when unlocked.
But pulling the rod that is connected to the inside door handle does nothing! It's as if the door is locked, all the time, from the inside, even when I know it is unlocked.
Has anyone run across such an issue when replacing the actuator? Could this be something simple like a sync problem?
Thanks!
Norman
'89 535i, 225000 miles, family owned... Williamsburg, VA
