Results 1 to 10 of 11
Thread: Slight burnt smell from vent.
    Windy City
    Default Slight burnt smell from vent.
    Recently, I smell slight burnt odor when I turn on the heater. This only happens when the temperature gauge hits 12 and only last few minutes. I have already changed cabin micro filter. Is there another filter or something else that can be done?
    RICK
    BMW 1995 525i (Alpine White)
    That could be your fan resistor burning leaves... I recently changed mine and there was a whole bunch of leaves, acorns and other stuff around there. That particular section traps alot of garbage before it gets to the filter.
    Maryland, Virginia, D.C.
    Yea, I just had a bunch of leaves swirling all over my car. Heater kicked in due to it being 28 degree F, and it smelled like a small fire. Went away after a few minutes. Tiger, do you know where the fan resister is? I'd like to give it a light check to make sure the car doesn't ignite.
    May 2006
    NH
    Quote Originally Posted by ThoreauHD View Post
    I know...
    Remove the driver's side (US SpecCar) Carpet Panel on the center transmission housing bump... look up in for a Blue plastic housing about three inches square with a wire harness plugged in to it. Pull that out of where its fitted,there are tabs on either edge of the part.It can take some effort to get it out but keep with. Once its out you may be able to get a vacume hose to that opening.
    1995 540i Manual build 1/95
    It is also covered by a bunch of thick wire looms... just push it aside and you can see tha tlight blue retangular shape.
    Windy City
    Thanks for the info Tiger... I never thought of that. But wouldn't it still cause it to burn entire time with heater on? The burnt order only last few minutes and is fine afterward.
    RICK
    May 2006
    NH
    not if the material is consumed or blown clear of the heat source
    First electrical draw is always the hardest... When I pulled my old one out to replace... it was covered with lots of stuff and I stuck my finger in the hole to find a ton more debis there...
    I had that burning smell before... no more.
    Nov 2006
    Mid-Atlantic, USA
    Sometimes the burning smell is because the resistor pack is beginning to fail. It's also hottest on low speed so turning it up to high will sometimes stop the odor if the pack is failing. . . or stop the leaf-burning, as the case may be. Take it out and see if you see any sign of burned electronics. The new part is only about $20.
    Windy City
    Thanks for the info guys. I'll have to check that out but too cold to! I'm not ready for winter yet...
    RICK
  1. Replies: 5
    Last Post: 02-13-2010, 07:29 AM
  2. burnt transmission...
    By kurt-o in forum 5 Series BMW
    Last Post: 08-02-2006, 12:45 AM
  3. Burnt out bulb in the radio
    By Jay 535i in forum 5 Series BMW
    Last Post: 08-26-2005, 03:33 PM
  4. a/c blows cold...top vent and lower vent blow hot?????
    By Anthony 94 525i in forum 5 Series BMW
    Last Post: 05-07-2004, 06:56 AM
  5. Burnt Plastic Smell
    By jbw535i in forum 5 Series BMW
    Last Post: 04-05-2004, 01:32 PM
