Hmm. Kinda managed to get one on. But chewed the hell out of the top bit (6mm squared off bit).
Howdy,
Almost exactly like my last thread...
here.
I'm trying to do up this nut on my rear shocker but the friggen shaft is turning with the nut. I can't really hold the shaft in place with anything because the nut isn't far down enough :-/. And I can't hold the shaft in place with clamps/wrench's.
Any ideas?
Picture below...
Ken, from Melbourne AUS.
'89 535iA with a 5 speed swap.
Try using some needlenose pliers wrapped in electrical tape below the nut. From the picture it looks as if there is a bit of space below the nut to grasp with thin pliers. Then once the top of the shaft is above the nut, use the needle nose pliers on top. HTH
If you have an impact wrench (electric or air), give it a quick shot.
Dave
You can grab the top of the rod through the spring with a vise grip and a rag, the shock never compresses that far so don't worry if you bugger it up a bit.
I'm in the middle of doing mine and luckily, like the OE ones, the KYB's I got have a hole for an allen key to fit into. I cannot use the impact but at least I can hold both into place while I tighten. How about a piece of rubber in some channel locks on the shaft until you can get it down farther.
1952 MG TD
1963 MGB
1967 MGB GT Special
1974 MGB Roadster
1991 Ford Ranger
1997 BMW 528I
2000 Harley Davidson Softail
2004 Ford Expedition
The fronts (both stock and Bilstiens) have the hex socket at the top of the stem. WAY easier. The rears don't. Though i've only seen Bilstien rears.
These new nyloc nuts grip the thread pretty damn well. I had vice grips on the shocker shaft pretty f'ing tight and it still spun doing up this nut...I wonder if they are THAT necessary. I think a 'flared' nut and LocTite should suffice.
