A little electrical system help: 90 535i washer system
My washer pump has quit working. To compound my problems, the E34 ETM doesn't seem to work with windows XP pro.
Here's some things that would be helpful:
- what are the ohm readings on the reservoir level sender when open, closed? (yes, not really related but I thought I'd fix it while I'm in there)
- which relay in front relay box is the washer pump relay?
I'm not getting any power to pump. The wipers trigger when you initiate the wash circuit and do the normal 5 sweeps and shut down. But, no power at the washer pump. Fuses look OK. So, I'm thinking I either have a problem with the relay or maybe (please, no) a broken wire. A broken wire is possible since I've had this system out a couple times when I replaced the engine.
Appreciate any help, need to get these suckers working with the miserable weather we are having out here.
Thanks, Jeff
Bellevue WA
86 Porsche 951 - Track Toy
