Bleedin' Bleeding !!!
Is this an M50 motor???
If it is, it's simply bleed, bleed and bleed again
Make sure you have coolant up to the Kalt level in your reservoir.
Raise your car up on ramps to get the rad bleed screw as the high point.
Set your heater on hot and run the fan, start car and get warmed up properly.
Then open bleed screw a touch and allow coolant to bubble out. When bubbling stops, tighten bleed screw and check coolant level in overflow...top up if necessary.
Take car out for a run around the block with heater full on, then allow engine to cool, then do it all again. Checking for bubbles from bleed screw.
Originally Posted by
angusbn
New BMW blue coolant, hoses, water pump and tstat.
Engine still runs very hot and the check engine light comes on after 10-15 mins driving.
I've tried to bleed the system a few times with no luck.
What's the fool-proof method to bleed the system?
Note that I have by-passed the heater core but I doubt that's the problem. No visable leaks anywhere.
Thanks.
"Uncle" Phil C
2011 Kia Optima EX-P.
Former owner of a 95 525i 5spd. "The GQ" aka A Shark in sheeps clothing
03 R1150RT 6spd. "DaRTth"
00 R1100R 5spd. "LeRoy"
