Is that fully built up with cams & manifolds? I've got a bare one kicking around and I can easily lift it with one hand, unless I am fiendishly strong that is (I'm 6ft 1 & 148 lbs!)
Cheers,
Shaun M
m20 head weight 52lbs
Cheers,
Shaun M
Just recieved it. Fully built up but no manifolds. Seemed heavy to me. Much more than two cylinders more than a 2002.
I am amazed. Some of the 'daft' 4 cyl 8-valve heads I've stripped weigh almost nothing. The heavier ones seem to be fitted with multiple hydraulic valves, the Ford I4 or BMW M50 spring to mind.
