good luck on removing the rear shelf with out cracking it.
Make sure you do your research.
Rear headrests form an E32 that happened to be the same as the E34 headrests. I'm also working on retrofitting the electric rear roller sun blind.
Anyone have pics of what the OE shelf that housed the sunblind looked like vs the non-sun blind shelf?
1994 540i Auto
live fast; die sideways
13.3 @ 104mph (not in the 540)
15.4 @ 150 Kph in the 540 (24/9/07)
I already took it out. looks solid and shows no sign of being brittle. btw: I spent 18 bucks for the headrests and bracket.
That's so cool for the headrest... I spent around $250 myself for all new stuff long time ago.
Nice. I have the rear headrests in my car too. Did you get the seat back as well and the plastic tops to the covers? If not, go back and trade them for the seat back or be sure you get the finishing tops where the headrests go thru the seat.
Also, nows a good time to treat them with some really good leather softener to keep the leather soft. They tend to really bake in the sun and get hard - the stitching will split. That sun screen of course will help.
Bellevue WA
86 Porsche 951 - Track Toy
I got everything, I cut my current seat backs to get it to go through. it was so easy. I put some leather cleaner/conditioner and in the spring I'll do the leatherique treatment.
are u sure about all that?
the e32 has a chrome loop type fitting and the e34 has a flat bar in the middle of the headrest.
and both have a completely different way of mounting
has on the 2 cars that I have anyhow
heres an e34 type
and heres E32
BMW 523i E39 Feb 1998 M52
Ho do u get the rear center armrest/storage compartment out of a e32? There is one in my pull a part and i couldnt figure out how to take it off, also the headrest. thanks
They're two 10mm bolts that you loosenform behind the seat (or from the trunk) to loosen the bracket that holds it in. To install it into an E34, like mine, i had to drill hols for the bracket to fit.
to Billy, the headrests that i got are the same as in the first picture. I got them out of an E32 though.
