Results 1 to 10 of 11
Thread: Glove box wont open :(
    Feb 2009
    Default Glove box wont open :(
    I recently bought my 540i and the glove box wont open, the handle lifts but it doesnt seem to actuate the mechanism, I first thought it was locked but does the same thing in both key positions.
    Both the hinges have fallen off the bottom of the box, so it is basically hanging on by the latch.
    Any idea's how to get it open without using brute force and ruining something?
    The hinge at the rear of the glove box is easily released with two clamps.
    This will give you a little access to try and free the latch(common failure) from inside.
    Does someone have a pic of the latch to help this guy understand how it catches?
    Unable to open the glove box Solution (procedure from Dhanraj R.)
    Slide under the glove box and you will find two snap latches connecting the back of the glove box to a metal rod (horizontal). Unsnap these two latches and the entire glove box will now be able to move forward by about 1/2".
    This will allow you some space to access and manipulate the latch from the top right edge of the box. Use a long, thin flat blade and depress the latch. (I had to look at a new replacement piece to understand what part of the latch to depress).
    With the glove box open, you will need to replace the latch. You will not need to replace the lock.
    http://www.bmw4life.com/microFilter.htm
    http://cgi.ebay.co.uk/BMW-E34-GLOVEB...20127003r35635
    http://cgi.ebay.com/ebaymotors/BMW-e...ayphotohosting
    http://cgi.ebay.com/ebaymotors/BMW-E...ayphotohosting
    http://www.digest.net/bmw/archive/v8/msg09288.html
    that is all I found.
    Apr 2007
    TX
    Haven't had to do this myself, but here are slightly varying instructions I found elsewhere on this board I think and saved just in case I ran into the problem.
    You can drop the back easy enough, but the latch has two wedges out both sides...you will *never* get those depressed with screwdrivers through the back of the glovebox. Here's the solution:
    Remove rear pivot clips as mentioned earlier.
    Pull toward you and wiggle side to side to loosen up a little. Pry downward. You're trying to create a gap at the top of the glovebox door.
    Find Phillips head screws in the gap between the glovebox door and the dash padding. Remove 4 in the center area.
    Pry downward until the sheet metal latch strike plate bends out from behind the dash where it had been fastened by those screws.
    Now you can get two screwdriver to depress the latch wedges on both side of the lock. Door will pop open.
    Using flatbar, bend sheet metal latch strike and tuck it back behind the dash - re-attached with screws previously removed.
    Aug 2008
    Pennsylvania
    Quote Originally Posted by Ross View Post
    Feb 2009
    Thnaks you very much, why does it fail? does the mechanism inside the latch break?
    Also, I assume once its open I should replace this part.... or is it repairable?
    Once you take it apart you will see the weak link. It's a small piece cast in potmetal, not repairable by ordinary means. the new latch is <$20
    Feb 2007
    I had to replace mine, its cheap and it takes 5 minutes to replace.
    Feb 2009
    The help is really appreciated guys, I'm going to give this a go today.
    I also have to diagnose the driver side window problem, it wont go down, but when you press the button to go up, you can hear the motor actuating, I suspect the switch may have gotten some corrosion on the contacts from standing for so long
    Feb 2009
    Thanks for all the help guys, I got it off.
    I pulled the door forward, undid the screws that I could see and then forced the entire unit down, bending the sheet metal plate down, then I was able to get a screwdriver in there to unlatch the lock pins.
    wrt the electric windows, I pulled the entire control button unit out, took the entire thing apart and cleaned everything. all windows work perfectly now.
  1. Hood on BMW e34 wont open.?
    By Inphinity in forum 5 Series BMW
    Last Post: 05-25-2008, 11:30 AM
  2. Glove box will not open
    By WILLIETOPZ in forum 5 Series BMW
    Last Post: 02-22-2007, 07:23 PM
  3. Passenger Door wont open...
    By Boone.Msi in forum 5 Series BMW
    Last Post: 01-12-2007, 08:19 PM
  4. locks wont open, need help
    By barry 90 525i in forum 5 Series BMW
    Last Post: 12-04-2006, 04:34 PM
  5. Glovebox wont open--Any ideas?
    By RayC. in forum 5 Series BMW
    Last Post: 11-16-2004, 06:47 PM
